-   -   350 sbc ring problem??????? (https://www.racingjunk.com/forums/showthread.php?t=20271)
HUNTER39 03-18-2008 08:38 AM
I am installing a new set of rings, standard bore, only thing different is that the cylinders was honed. I have used 2 different set of rings and the oil rings are to tight to fit in the bores. piston goes right in with comp rings. I also cleaned ring grooves with no luck. Any Ideas?
billhendren 03-18-2008 10:46 AM
Did you check the oil ring end gap? the rails may be butting.Bill
HUNTER39 03-18-2008 10:49 AM
ring gap
yes approx .025 oil ring gap
gimmemud 03-18-2008 11:02 AM
Make sure you have the correct radial thickness ring for your piston, in other words the ring could be thicker than the groove is deep.
HUNTER39 03-18-2008 11:13 AM
problem solved
in 87-88 they made a shallow groove pisto and the standard deep groove we have the shallow groove. Thanks for your input
