-   -   Electric fuel pumps, do i need a regulator? (https://www.racingjunk.com/forums/showthread.php?t=18328)
Blue68Camaro 09-08-2007 05:57 PM
What is the purpose of a regulator?
Thanks,
Tom
zipper06 09-08-2007 07:08 PM
Yes you need a regulator, because most good electric pump are capable of puting out 12/14lbs of pressure and that sometimes will blow by the neddle and seats in the carb. Most people set the regulator at 8lbs.
jbsjunk 09-08-2007 07:31 PM
If you're going on the cheap, Holley and Carter among others make a pump that doesn't need a regulator, Holley's red pump for example, I've run those alot with no issues.
Blue68Camaro 09-08-2007 07:46 PM
I have the holly blue pump as well as the mallory 140 series i think it is.
ozymaxwedge 09-09-2007 02:22 AM
Both of those pumps require a reg , they will run at about 12-14 psi you need about 7-8
http://i113.photobucket.com/albums/n...63/shed008.jpg
bjuice 09-14-2007 08:17 PM
Hey OZY..i would like to see more of your Mopar ?..
post some in the show off if you haven't already i will scroll over..
i am Chevy 1st...MOPAR 2ND.....Alawys been paretial to the Mopars since owning a 73 Doge Dart with a Canadian block 318 ..
red with white interior w/buckets and a white hockey stripe down the side..
Brian
Racefab57 09-15-2007 12:30 PM
Im chevy also but, I LOVE THE OLDS MOPARS!!! can remember riding my bike down to webster chysler, plymouth to see the new mopps in the showroom (that was a lloooonnnnggg time ago. show us more!!!!! David.
