It will be used for drag racing and some very occasional "street" driving, I am thinking of fitting a Procharger system to it, was hoping to use 98-100 ron pump fuel
That piston deck is designed for a N/A engine and could be milled to a flat top but no dish cut in it. I would not recomend this piston for a boosted application.
Thanks for your help
SBC Stroker Piston
ARussell,
I just hurt my 364 SBC. I am using TRW L2278 pistons. I have been told they are now obsolete and Federal Mogul/TRW/SpeedPro does not have a replacement. Does JE make a forged piston for a 364 SBC 5.7 rods that weighs about 540 grams? I need one piston. Thanks, Geo. |
Geo,
I apoligize I dop not have an old FM book, is that a flat top piston? |
Info for TRW L2278 .030 Piston
ARussell,
I looked through my stuff and here's the info that I have. The is a Forged Aluminum Piston for a 364 SBC 4.030 x 3.562 Comp Dist 1.52 Dome height .193 Comp Ratio 12.5 w/ 64cc heads Effective Dome Volume 9.6 cc Weight 575 grams with no rings and no pin I hope this info helps. Thanks again, Geo |
L2278 Pinton Info
ARussell,
One more piece of info. The piston has a 1/16, 1/16, 1/8 ring groove configuration with normal ring groove spacing |
I am sorryt but all I have are flat top pistons that weigh 475g. Best of luck to you, obsolite parts are hard to find.
Does JE make a SRP piston for a 4.6100 Bore, be 4.375 stroke, 6.385 rod. Making a 584 CI BBC
We only have a piston for the 6.535 rod, I am not sure there is a crakn that is 4.375 stroks that will clear a 6.385 rod. I have parts to fir an conventional open chamber head and a 18 deg big chief.
| All times are GMT -8. The time now is 06:29 PM. |
