-   -   PLEASE I am in need!!!! part 2 (https://www.racingjunk.com/forums/showthread.php?t=32284)
TheYellaBrick 07-05-2012 07:57 PM
In that video what I thought was the water pump is the balance shaft. The 'unknown' is the WATER PUMP.
So what the heck is what I thought is the balance shaft ? :?: :?: :?:
mopar1968 07-05-2012 07:59 PM
Can you spin the gear in guestion :?:
TheYellaBrick 07-05-2012 08:01 PM
re video;
AK ! It's not even the same engine........
fast75vega 07-05-2012 08:01 PM
according to alldata... you got it labeled right.... the one u were not sure about is your oil pump drive
mopar1968 07-05-2012 08:03 PM
Now we know what that gear is :!: But it doesn't sound too good :!:
Mark
TheYellaBrick 07-05-2012 08:17 PM
Found another vid with the proper engine, it IS the water pump....an EZ do.
Still want to find out what that other shaft is. Now that I think about it, that shaft on the left in my pic turns with some soft resistance as in cold oil,...oil pump maybe....
Mark, you sent me in a good direction off of that first vid.
FastV, Thanks for YOUR effort as well !
TheYellaBrick 07-06-2012 08:06 PM
AAAAAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaaaaa
aaaaaaaaaaaaaaaaAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
Got the new pump installed, timing and drive belts on, spun it over to test fire it and :x :x :x :x Had a DUMBA SCHITT moment. I had reinstalled the crank position sensor but APPARENTLY did not get it seated properly cus when I cranked it over that sensor got all balled up into the drive belt. Anywhere from $75 to $234 for a new unit. :oops: :oops: :oops:
DAMN RICERS...................................
