-   -   stud girdles (https://www.racingjunk.com/forums/showthread.php?t=22933)
twobad1 02-19-2009 02:39 PM
i broke a rocker stud twice b4 i bought mine but it had 3/8studs
510hyd
chevyfireball 02-25-2009 01:03 AM
I broke a rocker stud in my 572ci Camaro. If it hadn't been for the girdle it would have gotten ugly real quick.
ashbros 03-11-2009 08:52 PM
Don't leave home without them!
desoto30 03-12-2009 11:07 AM
Originally Posted by dparker
Sunset Racecraft racing engines does not run them and has great luck. Last year at Indy it was said that 75% of the sportsman class had Sunset Racecraft engines. There reasoning is that when you put a stud girdle on it pulls some of the rocker studs to where some are in a bind causing them to fatigue and later brake. Its is true you have a extra lock, but you also have to loosen an extra thing to adjust. But on the contrary, Reher Morrison builds a great engine and uses stud girdles. I believe there reasoning is that it takes the harmonics out of the valve trane that causes fatigue. I have one of each and both are great engines. I've not had to readjust either.
great post which just goes to show that there is never only one correct answer/way to do things.
