-   -   engine oil dip stick (https://www.racingjunk.com/forums/showthread.php?t=21711)
kwkracing 08-28-2008 09:02 AM
I have used a small bolt and some black silicon for this
ARUSSELL 08-28-2008 10:30 AM
The plugs that go around the cam fit.
us7race 08-29-2008 08:42 PM
I have a dipstick tube that I welded a strap to to bolt it in the block right below the dipstick. You could do the same and add some silicone to it before you slide it in..should fix the issue. I was using a chrome dipstick too. I can probably post a picture sometime if needed..
desoto30 09-11-2008 10:38 AM
Originally Posted by ARUSSELL
Pull out the dipstick and put a freezeplug in the hole. I have a site pulg in the side of my oil pan and with this setup no leaks!!!!!
I'm with you an this one I used a wheel weight lead cut it & hammered into the hole noy realising that a cam oil gallery plug fitted, the lead worked a treat too
