This has nothing to do with boxing the frame.....which I wouldn't bother with anway but, have you done some research on the extensive modifications needed to install a 632 in you car?
The fronnt crossmember needs to be notched for pan clearance because of the stroke. And Steering modifications or switching to a rack setup will be needed to clear the pan also. Also plan on spending at least 1200-1500 for headers to fit in the car. Just wanted to give you a heads up if you haven't researched it too much. |
| All times are GMT -8. The time now is 11:02 AM. |
